dsm1212
Mar 13, 2015Apprentice
Qbittorrent update
The qbittorent included in the readynas distribution is quite old (2.9.8-1) and buggy. It appears there are newer compatible ubuntu built distributions available. For example, see here: http://www.tecmint.com/install-qbittorr ... -in-linux/.
I installed add-apt-repository and of course it doesn't work on os6 because of the netgear damaged ca-certificates package. Has anyone gotten a newer version of qbittorrent running on OS6 and could you share instructions?
steve
steve
- super_poussinVirtuosoThis is the last available version for headless Linux machine
https://packages.debian.org/wheezy/qbittorrent-nox - dsm1212ApprenticeDo you mean for wheezy or ever? I see other builds of qbitorrent-nox on newer distributions. That link in my first message seems to indicate that there are new PPA builds that will work on Debian 7 available. but maybe they don't have qbittorrent-nox?
thanks
steve - dsm1212ApprenticeI got off my butt and set up a build environment in a virtualbox and was able to build v3.1.12 fine. I installed super's addon and then dropped libtorrent-rasterbar.so.7 into /usr/lib and updated qbittorrent-nox. Those two files were all that was needed and it runs fine.
steve - super_poussinVirtuosoSteve can you share the files so I will update the addon ?
- dsm1212ApprenticeSent via pm..
- super_poussinVirtuosoThanks to DSM1212 , QBittorrent 3.1.12 is available as Haddon :)
Check the community dropbox - h3nk3tTutorHi there everyone
I tried to install latest qbittorrent from super-poussins dropbox. It's version 3.1.12. I can't toogle the app on from web-gui. I also tried to start it up from SSH without success. I've googled my problem for many hours and according to almost every user they can manage to start qbittorrent.
The old version 1.0.3 worked flawlessy and problems started when I installed the latest version. I can't go back to 1.0.3 either. It won't start anymore
Do I need to wipe any config/cache somwhere?
I prefer to use qBittorrent before Transmission mainly because when I'm downloading many torrents at the same time qBittorrent handles the situation much better.
Please someone help me out here
Many thanks
Henrik - dsm1212ApprenticeDo you have ssh access? If so, post the output of:
ldd /usr/bin/qbittorrent-nox
This will show if there are any missing library dependencies. Maybe there is a library I already had on my system that I needed to tell super about. Just guessing.
steve - dsm1212ApprenticeOh yes, and it just worked on OS 6.2.2, what rev are you running where it won't start?
I'm on latest 6.2.3 beta 11. Now the qBittorrent .deb file is missing in Super-Poussins Dropbox. Unfortenately i can't find any installation files. Can you provide me with those please.???
THANKS / Henrik Sweden
