× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Minecraft Port Fowarding
Zoiinkzz
So I have a D6220 router (not an option to put in for some reason) I’ve been trying to forward my ports to play minecraft (25565) with my friends for at least 2 days now, I’ve watched videos and done everything the same step by step of the way but my ports never open and no matter what I do they won’t open, can anyone please help cause this is beyond annoying
Message 1 of 12
Accepted Solutions
antinode
Guru
Re: Minecraft Port Fowarding
> I'm not too sure what you mean by value here
   The _numbers_.  The actual _numbers_.  Not "like xxx.xx.xx.xx" or
"the number i get when i search for my public IP".  The actual
_numbers_.  I don't even need _all_ of them; the first half would be
fine:
> [...] "a.b" out of "a.b.c.d" would be enough.
> [...] im sorry but it dispays like xxx.xx.xx.xx but that number does
> not match the number i get when i search for my public IP
   That could be your problem:
      https://en.wikipedia.org/wiki/Carrier-grade_NAT
   If your ISP is using carrier-grade NAT, then your router will not get
a public WAN/Internet IP address, and so you will not be able to make
port forwarding work.
   You could try asking your ISP if you can get a public address.  They
might charge extra for that, if they'll do it at all.  Some ISPs dislike
servers for residential customers.
Message 10 of 12
All Replies
@Zoiinkzz wrote:
So I have a D6220 router (not an option to put in for some reason) ...
Probably because it is a modem/router and you have posted in the section given over to Nighthawk WiFi Routers. You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
DSL Modems & Routers
@Zoiinkzz wrote:
.... I’ve watched videos and done everything the same step by step of the way but my ports never open and no matter what I do they won’t open
Did your research include a search of this place for Minecraft?
Search - NETGEAR Communities – undefined
Lots of hits.
There are people here who understand these things, but they can't help without clear details of what you want to do and what errors and messages you see when you try to do it.
Message 2 of 12
Zoiinkzz
I’ve checked them all, one was similar but they had a modem and router separately but I just have one, if it’s a router modem combo what am I meant to do to fix the port forwarding?
Message 3 of 12
@Zoiinkzz wrote:
...if it’s a router modem combo what am I meant to do to fix the port forwarding?
You should be able to ignore the modem bit.
Your router is the same as the standalone router when it comes to things like port forwarding.
Message 4 of 12
Zoiinkzz
So then port forwarding should be working right? But it’s not I’ve done everything right and followed tutorials to the letter but it’s still not working
Message 5 of 12
antinode
Guru
> [...] I have a D6220 router [...]
   Connected to what?
   ADVANCED > ADVANCED Home : Internet Port : Internet IP Address?  Does
that address match your public IP address?
> [...] I've watched videos and done everything the same step by step of
> the way [...]
   That non-description conveys no useful information to the
non-psychics in your audience.  Who also can't see your port-forwarding
rule(s).
> [...] I've done everything right and followed tutorials to the letter
   It's nice that you're happy, but, again, no idea of which
"tutorials"; no idea of what you did.
> [...] but it's still not working
   No idea of how you determined that, either.
   None of that is a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
Message 6 of 12
Zoiinkzz
so basically from the start i find my IPv4 from cmd ipconfig, enter that into the port forwarding/trigging section press add and enter the ports i want forwarded which is (25565) click apply and that should be it but when i go to any port checking sites it will say that the 25565 port isnt open with the server running or not. I dont see any error messages or anything like that it just doesnt show up that the ports are open on sites like canyouseeme.org
One thing you said though was if my public IP matched what it said in the Advanced Home page and it doesnt, when i go to look at it the box that says "get dynamically from ISP" is checked
Sorry if its too vague but thats practically all the info i know
Message 7 of 12
antinode
Guru
> [...] i find my IPv4 from cmd ipconfig, [...]
   That address could change at any time.  Visit
http://netgear.com/support , put in your model number, and look for
Documentation.  Get the User Manual.  Read.  Look for "Address
Reservation".
> [...] enter that into the port forwarding/trigging section press add
> and enter the ports i want forwarded which is (25565) [...]
   I still can't see any of that.  There are some parameters in a
port-forwarding rule: Name, Type (protocols), External ports, Internal
ports, and Server IP Address.  What, exactly, are yours?
> [...] if my public IP matched what it said in the Advanced Home page
   I didn't say "in the Advanced Home page".  There are many things on
that page.  What I requested was, specifically:
What is that value?  "a.b" out of "a.b.c.d" would be enough.
> [...] when i go to look at it the box that says "get dynamically from
> ISP" is checked
   "go" _where_, to look at _what_?  "Get Automatically from ISP" is not
a problem.  The actual _address_ which you "Get Automatically from ISP"
may be a problem.
> Sorry if its too vague [...]
   It is.  Actual numbers would be more useful than your descriptions of
those numbers.
Message 8 of 12
Zoiinkzz
> go to the manual
I went through the steps the manual showed and in LAN Setup which is where i reserve and IP adress the one i get from cmd ipconfig was already on the reserve list
>some paremeters in a port fowarding...
So for the name i just named it "Minecraft" so i remebered what it was for, Service Type is TCP/UDP, External Starting Point: 25565, Internal STarting Point: 25565 and the internal IP address is the one I get by selecting the computer im using which is also the same as the IP I get from cmd ipconfig
ADVANCED>ADVANCED home : internet port : internet IP address
I'm not too sure what you mean by value here im sorry but it dispays like xxx.xx.xx.xx but that number does not match the number i get when i search for my public IP
>Get what from where
From here i go to the Internet Setup tab and find the section that says "Internet IP Address" and just below that is the box that is checked "Get Dynamically From ISP"
Message 9 of 12
antinode
Guru
fine:
Message 10 of 12
Zoiinkzz
So when i search for my public IP on the internet it say that it is 117.20.xx.xxx
but when I look at Advanced>Advanced home>Internet Ip Address it is 100.88.xx.xx
I will contact my ISP and see if its something on their end in the mean time
Message 11 of 12
antinode
Guru
> [...] when i search for my public IP on the internet it say that it is
> 117.20.xx.xxx
> 100.88.xx.xx
   That looks like the problem.  Plug that "100.88.xx.xxx" address into
the form at "https://whois.arin.net/", and get discouraged.  (Compare
with what you get from the "117.20.xx.xxx" address.)
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 10338 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
