× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Need time restrictions in parental controls
dugnsarah
Follower
Just bought a Netgear AC1200 to replace my old Linksys Wifi router.  My old router allowed me to set up time restrictions on specific devices, so that the wifi was cut off to my kids' devices late at night.  I thought from reading the box that Netgear could also do this, but I can't find it in the parental controls.  Please let me know how to set this up - thanks!
Model: R6100|AC1200 Dual Band Router
Message 1 of 2
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Need time restrictions in parental controls
Hi @dugnsarah,
The Parental Controls feature will allow you to set filtering level on the connected devices on the network and does not cut off the Internet connection. You can check the links below for an overview of some of the features of LPC (Live Parental Controls).
http://kb.netgear.com/app/answers/detail/a_id/25687
http://kb.netgear.com/app/answers/detail/a_id/29913
However, if you want to cut off the Internet access on the connected devices, you can use the Access Control feature either via the router's UI or through the NETGEAR Genie app. You can check the links and steps below:
http://kb.netgear.com/app/answers/detail/a_id/23289
http://kb.netgear.com/app/answers/detail/a_id/24830
Via the NETGEAR Genie app:
1. Install the latest version using the link below:
http://netgear.com/home/discover/apps/genie.aspx?cid=wmt_netgear_organic
2. Open the program/app
3. Select Network Map
4. Login using the router's credentials (default: username is admin password is password)
5. Check the box "Turn On Access Control"
6. Select the device that you want to block
7. Click on "Block"
Dexter
Community Team
Message 2 of 2
All Replies
DexterJB
NETGEAR Moderator
Hi @dugnsarah,
7. Click on "Block"
Dexter
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 13987 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
