Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AC1600 for Router with Netgear N300 WNR2000V4 for AP/Modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
02:53 AM
2020-12-07
02:53 AM
I have an old and 300 modem/router combo. I recently bought a night hark AC 1600 smart Wi-Fi rider model number R6260. I would Iike to disable the router feature on the old N 300 to use as modem only and use the nighthawk for a router. How can this be done? Doing an AP?
Model: R6260|AC1600 Smart WiFi Router Dual Band Gigabit, WNR2000v4|N300 Wireless Router|EOL
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
06:10 AM
2020-12-07
06:10 AM
Re: Nighthawk AC1600 for Router with Netgear N300 WNR2000V4 for AP/Modem
the WNR2000V4 is a router. Not a modem/router combo device.
If you have a combo device, what actual model number is it?
If you go to netgear.com/support/ type in the actual model number and it'll take you to the manual with the info to disable router mode.
You also posted in the mobile router forum. you might have better luck in the dls or cable modem forum (not sure which because the wnr2000 is a router only)
https://community.netgear.com/t5/Cable-Modems-Routers-and-DSL/ct-p/en-home-dsl-and-cable-modems
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
08:40 AM
2020-12-07
08:40 AM
It's not a combo? I've used the n300 for about 4 yrs as a stand alone modem/router. Not hooked up to a modem. I bought the nighthawk last night thinking it would work as a stand alone. It does not from what it appears ??
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
09:14 AM
2020-12-07
09:14 AM
Your old device was the WNR2000? and there's nothing else connected to it?
Who's your isp?
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-07
10:04 AM
2020-12-07
10:04 AM
Yes that is my old device and used as a stand alone. EPB is my provider. It our local power company. Guess I should call them.
Message 5 of 5
Announcements
