- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port forwarding wont save
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I have a WNDR4300 and i want to port forward various ports. A while ago i forwarded port 80 and that worked fine, but now if i want to port forward any other port it dosn't work. i click add custom service and enter the port i want forwarded and choose the local ip address then click apply. It dosn't show or come up with any errors or messages but just takes me back to the main port forwarding screen and the entry i just made is not there! I have checked that is has the latest firmware but I am wondering if it could be a corrupt firmware version or something. Please help me!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, your post 8, after changing firmware did you factory reset the router, using the small pin-hole reset button?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port forwarding wont save
Hi @Matt9378,
Welcome to the community!
Sounds like it might be a corrupted firmware. Have you tried resetting the router for 10 seconds? If not please do so and see if it helps.
If the same thing happens, I suggest that you reflash the firmware of the router. Download the latest firmware on the website and upload it.
See this link on how to do firmware upgrade.
Let us know what happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have many times reset the router for over 10s but to no avail.
I'll try the firmware flash now and report back if it works or not.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nope didnt do anything 😞 It all worked correctly and uploaded and installed but i still cant save the ports.
Im thinking of going to DDWRT.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you running any applications/plug-ins that might interfere with the way the web browser works with the router e.g. adblocker has been tied with similar issues in the past?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hmm... Good idea! I'm gonna try to use a different browser with no plugins.
I'll Report back. 🙂
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nope 😞 Tried it on 3 different browsers all with no plugnis and I tried it on 3 different comps.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is very odd isn’t it? Port forwarding is a pretty fundamental function of the router and the situation you describe would not go un-noticed if it was prevalent. The fact that the issue remains after the re-flash of firmware is also odd.
I suggest that if you wish you make a current backup of your router settings, then flash with an older version of firmware (available by following the ‘Downloads’ link at the top of this page). After flashing firmware make sure you factory reset and then enter settings manually (don't use a saved configuration file), start with the Port Forwarding rules to see if that now works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here we go...
I'll Report back.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok I rolled back the firmware to 1.0.1.30 from 1.0.2.80 and that worked ok so then i went to reset the settings but...
This shows even after a reboot- Mark as New
- Bookmark
- Subscribe
- Permalink
Well I would normally think that is a browser issue, maybe a refresh problem or adblocker type issue that we have seen in the past, but you have tried multiple browsers / multiple PCs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried 3 different comps 2 ethernet 1 wifi and i have tried opera(no plugins) firefox(no plugins) chrome(no plugins) chrome(plugins) and all of them have the same result! getting a bit frustrated.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No I havn't tried that. I will but im gonna do it later.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep! 🙂 I just reset the router by holding the little red button down and then manualy put in the wan settings and boom it worked!
THX!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well that’s good. In that case when you are fully happy with your settings I suggest that you save the router configuration to a backup file, then in future if the issue re-appears you could try another factory reset and restore from that backup.
