- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6300v2 Port Forwarding no working on Port 19132
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have built a server, and trying to build a Minecraft server for my son. It is setup properly, windows firewall has the approriate rules in place. I set the port forwarding on the router and cannot connect.
My router is a static IP address, and I have two separate outside networks here. I am attempting to access the server via the software from an outside network with no success.
i have even used canyouseeme to see if the port is open and it states it is not.
I have the R6300v2
firmware is the latest
Firmware Version
V1.0.4.2_10.0.74
Any help would be greatly appreciated
Thank you in advance
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you verify that the server is up and running by connecting from a local PC?
yes I RDP into the server, start the software, watch it start up and run.
I am unable to connect to the minecraft sever on the LAN or externally. According to all instructions I have it configured properly, just not sure why I cannot connect.
thanks anyways for the help.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6300v2 Port Forwarding no working on Port 19132
Does the R6300v2 have a public or private IP address on its Internet/WAN port? If it's private, then you have another router, likely your ISP's. You would either need to set up port forwarding rules on that router, or convert that router into a bridge.
- Mark as New
- Bookmark
- Subscribe
- Permalink
it is a public IP address. The modem/router from my ISP is a bridged router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you confirmed that your Minecraft server is assigned with the IP address that matches the port forwarding rule? You might want to set up an IP address reservation on the R6300v2 in order to insure that the IP address doesn't change.
If the address is correct, then try rebooting the R6300v2. Just a plain power cycle. Then, confirm that the port forwarding rule is still there. If you are not using UPnP, then turn it off to avoid any potential conflicts.
Finally, you can try enabling Open NAT under WAN Setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok,
the machine that the minecraft server software resides on, I have checked a doubled checked the IP address.
NAT is set to OPEN
I have rebooted the router. PF still there.
Now I do have UPnP on because of other applications. I will disable to see if that is the problem, but I hope not.
will Let you know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok,
tried dis-abling UPnP, rebooted router, still nothing.
Re-installed minecraft PE Server, still not able to connect nor when I go to canyouseeme.org it states the port is closed.
Let me know what else I can try. I am stumped.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Intead of using canyouseeme.org, have you tried connecting from a remote PC?
If the answer to both questions is, "Yes," then I don't have any other ideas.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you cannot connect to the server from your LAN, then your server is not running properly and this is not a port forwarding issue. You need to fix your server before port forwarding will work.
Does netstat -rn on the server show it listening to port 19132?
