- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6400v2 router - app won't update firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
The nighthawk app repeatedly gives me an error message when I try to update the firmware.
The "download" for the firmware on the website gives me a document that my computer doesn't trust, and an html link that sends me back to the same download link that gives me the same zip file...
Trying to use the link to login into my router leads me to a page that won't let me log in, then sends me in circles in the same way as above, back to the same page.
It's like inception for routers.
My firmware version is V.1.0.4.106 which is probably a few updates ago, but I think every time I try to update this is what happens, and I give up. I don't have time for this--who does?
My app is up to date. I've tried rebooting the router and trying again and that doesn't work either. Maybe a hammer?
Can anyone help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400v2 router - app won't update firmware
I'd recommend upgrading over a hardwired connection using a pc/laptop.
Tends to work the best be the most stable.
when you download the file, it'll be in a zip file that you then extract.
After extracted, you follow the manual update process.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
As I said in my post, I tried the router login route--I can't seem to login and when I follow the prompts for if you can't login, it sends me in a recursive loop back to the beginning.
The steps don't work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
have you tried other pc's/browsers?
Or even a simple factory reset?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I guess I'll try that. It shouldn't be this hard. Thanks for your suggestions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What does that mean? In what way "does not trust"?
If you get the firmware from the Netgear site, it comes in a zip file with the firmware and release notes.
There have been three since then:
R6400v2 Firmware Version 1.0.4.122 | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You don't "open" the file. Once its extracted, you follow the manual update process and upload it to the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You know, I'm a person who uses a computer, not an engineer. First of all, the app should work. Second of all this should not be so hard.
When I got to routerlogin.net I get an error message.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The process is fairly simple to walk through. Thats why theres the steps. It doesn't take an engineer.
And I'd agree, the app should work. Sadly, we see alot of the time where it doesn't. But we're not netgear. We're the public support forum where members of the public help out. So there's nothing we can do about the app.
But we can give you ways of getting it updated. The process I outlined is the safest, stablest way I can give you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I appreciate your time. I will try to follow the steps. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hope it works for you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are right there. Other people also have a hard time with these things. That's why Netgear tries to make things a bit easier.
Newer routers have the option to update themselves "under cover". They sneak out and do it when you are not looking. It wasn't there in the original R6400v2, but maybe they added it in new firmware.
This isn't a perfect process, and those with an "engineering" turn of mind turn it off. When you do fix your device, you could see if it also has that option.
As others suggest, tell us what those errors are and someone may be able to help. It isn't often that a brand new problem crops up here.
Your very act of working out how to use this place – again not as easy as it could be – shows that you are well on the road to recovery.
