pkliot
Nov 23, 2022Aspirant
Slow Wired Connection AC1200 R6230
I recently had AT&T fiber installed and I now have roughly 980 mbps coming from my AT&T modem if I directly connect my computer to the modem. If I connect the AT&T modem to my R3230 router and connect my computer to the Ethernet port on the router I'm only getting around 345 mbps, the port on the netgear router is supposed to be gig speed. Any idea why I'm not getting full speed? My cables are all cat 6
Thanks
Did you reset and reconfigure your R6230 after you installed the new Internet service?
do you have the R6230 in AP mode?
Or the R6230's ip address put into the att gateway's DMZ?
Otherwise you're in a double nat
Do all AT&T modems do that?
No option for "bridge mode"?
Dontcha hate these ISPs?
ATT pretty much forces all its users to have a gateway that's not just a modem. A bit sad you can't just get a modem from them.
- pkliotAspirant
Thank you for your response,
I didn't put it in AP mode, I'll put the IP into the DMZ when I get back to work and see if that fixes the problem.
