BSS_BT-SC_ENG3's avatar
Jun 19, 2018
Using Readyshare USB for Raid storage
Hello,
I work for a company that develops security cameras. We are setting up two PCs with seaparate image quality testing software and would like to create a central, local storage space for the two computers to store and access test images and results. My plan is to use the AC1750 Model R6400v2 and its Readyshare port to share two SSDs connected to the Startech USB3.1 RAID enclosure Model S252BU313R as the storage. After much research and little budget, this seemed to be the simplest, cheapest solution.
A few things about our setup: Our test PCs do not access the internet in any way. The AC1750 will have its wireless antenna turned off and nothing connected to its internet port. The four switch ports will be used simply for each computer and another network switch that has our test IP cameras connected to it. Each computer is set to static IPs of 192.168.0.100 and 192.168.0.200 as the cameras are generally set to 192.168.0.1-99 for testing purposes.
I'm curious what steps need to be taken to make this work. I know the router comes defaulted to 192.168.1.1, but I can change that IP to something within the range that each computer can see. What other settings need to be changed (DHCP, etc) so that each computer can connect to the Readyshare device?
Thank you for your time!
  • I appreciate that you're trying to help (I think), but I'm really not interested in advice given in solely sarcastic and condescending words. You may be an expert in this field and require information about certain settings and parameters that I have not even considered, but simply stating that I'm not being detailed enough without being detailed yourself about what exactly you're missing (as far as information is concerned), I can do nothing more.
    I've ordered a NAS storage system so I will not be continuing this project. Thank you both for the time you did take to respond.
  • michaelkenward's avatar
    michaelkenward
    This might not work. ReadySHARE is a basic approach to network attached storage that does not play nicely with odd enclosures or anything that needs fancy drivers in Windows.
    Did you consult this?
    ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
    It isn't complete or up to date, but it may give you some clues.
    For anything beyond the routine there really is no substitute for ethernet NAS boxes.
    • BSS_BT-SC_ENG3's avatar
      BSS_BT-SC_ENG3
      Thanks for the suggestion. I had not checked that and the SSDs I'm using are not on there.
      However, the RAID enclosure does not require any drivers and when the computers are set to obtain an IP from the router and DHCP is turned on (like a normal set up), everything works fine. Ideally we'd like to set the computers to static IPs per company policy but maybe I can work around it. So, if I set the computers to their static IPs and turn DHCP, no go. I'm assuming the router needs to use the DHCP server to brodcast the Readyshare device?
      Maybe I'll just bite the bullet and get a NAS server.
      • antinode's avatar
        antinode
        Guru
        > [...] would like to create a central, local storage space [...]
           How isolated would you like this equipment to be from your general
        network?
        > [...] My plan is to use the AC1750 Model R6400v2 and its Readyshare
        > Model S252BU313R as the storage. [...]
        > [...] I had not checked that and the SSDs I'm using are not on there.
           I would not bet that Netgear ReadySHARE knows what to do with SSD
        storage.  Whether that RAID enclosure hides those details from its host
        is another mystery.  A search of these forums should find abundant
        complaints about plain-old rotating disks v. ReadySHARE.  My experience
        with it is minimal, but I view it as a dancing-bear system, and wouldn't
        trust it for serious work.  Others may be satisfied with it.
        > [...] What other settings need to be changed (DHCP, etc) so that each
           I don't think that anything special needs to be done for ReadySHARE
        itself; you'd just need to configure the router to be compatible with
        whatever network to which it'd be connected, which shouldn't be a
        problem.
        > [...] Ideally we'd like to set the computers to static IPs per company
        > policy but maybe I can work around it. [...]
           "work around" _what_, exactly?
        > [...] So, if I set the computers to their static IPs and turn [off?]
        > DHCP, no go.
           "no go" is not a very detailed problem description.
        > [...] I'm assuming the router needs to use the DHCP server to brodcast
           I doubt it.  But, with my weak psychic powers, I know nothing about
        how you configured any of these devices, or what you did with them, or
        what happened when you did it.
           If you want reliable NAS, then that might be a good idea.  However,
        if you already have the router and RAID box, and if when "DHCP is
        turned on", "everything works fine" (for some value of "everything"),
        then perhaps you should try to figure out what you're doing wrong with
        the non-DHCP network configuration which causes this (vague) "no go"
        condition.
