hennrike's avatar
hennrike
Wifi 2.4Ghz very slow on my R6250 Router
Last week I bought a R6250 Wifi Router, and I have problems with 2.4Gb wifi connections. They are too slow.
I have 300 Mb (download) and 30 Mb (upload) with my ISP provider. With 5Ghz Wifi connection I have more than 200Mb for download and 30 Mb for upload, but with 2.4Gb Wifi connection I have 15/20 Mb for downloading and only 1-5 MB for uploading. With my old 2Ghz wifi connection I had 35/40 Mb for donwloading and 20/30 MB for uploading.
I'm using speedtest app on mobile devices to do the speed tests.
The firmware version is V1.0.4.2_10.1.10.
Can anyone help me with this problem? Any recommendation?
  • Hi Dexter,
    Last night I did only a few tests.
    I've changed the wifi channel to value 1, and the results seems to be better: donwload speed between 25 and 42 MB and upload speed between 20 and 30 MB.
    I'll continue some days with this configuration.
    Regards
    • hennrike's avatar
      hennrike
      Thanks Dexter,
      I respond you:
      1: Yes, all devices experience the same issue with the 2.4GHz. I've been testing with a Huawei P8 Lite, Moto G First Generation, and iPhone 6
      2: No, I have no try resetting the router. I'll try tonight
      3: No, the wirless channel is in auto mode. I'll try change the channel tonight.
      Regards
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi @hennrike,
        Please keep us posted on the results.
        Dexter
        Community Team
