Heardy
Oct 26, 2016Follower
Configure virtual server for range of IP addresses
Hi,
Does anyone know of a model router that will allow for a new virtual server connection for a range of IP addresses?
Basically on the old router i had port forwading setup for a site to connect using terminal services.
The WAN side they could come in on any IP from 217.41.87.36 through to 21.41.87.40 and this would allow them to use terminal services to connect to the server. On the new Netgear routers there doesn't seem the option to be able to do this.
Many thanks
Andy
1 Reply
- kohdeeNETGEAR Expert
That functionality is supported on our business routers, not the home routers. You can use a feature called "secondary addresses" on the WAN port to assign multiple addresses that would receive incoming traffic and then you can create NAT rules to forward the traffic per WAN port.
*moving post out of the wireless community
