dvenardos's avatar
dvenardos
GC108P with IoT VLAN
I am trying to separate IoT devices (Sonos, iRobot, Nest, etc.) into a separate VLAN but still discover and access them from a trusted VLAN. Does the GC108P support Bonjour / Multicast forwarding by itself or does that require a separate firewall / router.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    dvenardos,
    Welcome to the community! :)
    The GC108P supports Internet Group Management Protocol (IGMP) snooping which allows a switch to forward multicast traffic intelligently. Kindly read pages 168-182 of the GC108P user manual here about IGMP snooping.
    You can also manage the Bonjour settings on the GC108P.  Kindly read pages 79-80 of the GC108P user manual here
    DaneA
    NETGEAR Community Team
    • dvenardos's avatar
      dvenardos
      Thanks for the response.
      Pages 79-80 seems to refer to Bonjour in relation only to being able to discover the IP address of the switch itself, whereas, I am inquiring whether or not Bonjour will work across VLANs. By default Bonjour only works within the same subnet. Specifically I would like to get AirPlay to work across VLANs (i.e. Apple devices can Airplay to devices in the IoT VLAN).
      • schumaku's avatar
        schumaku
        DaneA not sure this feature applies to inter-VLAN-routing capabilities. I'd tend to deploy a router or securty appliance to add multicast routing such a network.
ProSupport for Business
