Orbi WiFi 7 RBE973
Reply
GC510P shows disconnected but is working
Lsands
Tutor
Symptom: Insight shows 4 of my 6 switches as disconnected, but they are working fine.
I have 6 GC510P switches at a location. When looking at the switches, they all show they are connected to the Internet (blue light is on). They are all functioning properly (various cameras and access points on separate vlans all work). When I use Insight to look at the switches, 4 of them show "device is disconnected"; it's been this way for over a week. They got out of sync when I upgraded the firmware.
In the past, they only way I could get Insight insync with the switches is to manually reboot each switch.
The location is connected to the network using an airbridge. I don't know if this impacts something.
Any ideas on why the hardware isn't in sync with Insight?
TIA, Louis
Message 1 of 3
schumaku
Guru
Re: GC510P shows disconnected but is working
The switches try to establish a cloud session -to- the Insight infrastructure.
Anything changed in the data path prohibiting the switch LAN IP addresses to reach the Internet?
Message 2 of 3
Lsands
Tutor
Thanks for your reply.
The path was interrupted when I updated the firmware on another switch. That switch connected the network to Internet. Once the pathway is restored, I expected the switch to talk with Insight. What I find crazy is that the blue light on the switch is lit. That indicates there is a connection to the Internet. The only way I have found to get these devices to appear connected in Insight is to power cycle them, and that doesn't always work. Clearly Netgear has a software bug.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 546 views
  • 0 kudos
  • 2 in conversation
Announcements
