AWENA
Oct 11, 2022Aspirant
Bricked Netgear M4300-52G (GSM4352S) via "Erase Permanent Storage" from CLI
Hello, accidentally deleted the Permanent Storage via CLI
found this article but it didn't help:
https://alastair.d-silva.org/bricked-netgear-m5300-switch-erase-permanent-storage
m4300r2> fatload usb 0:1 ${loadaddr} /boot.stk
Unknown command 'fatload' - try 'help'
I understand that must execute the following command: "ubifsload"
but I don't know the syntax options "<addr> <filename>"
Please, help
Now I have the following in terminal:
U-Boot 2012.10-00245-g79946b8c89 (Feb 21 2018 - 17:08:40)VerNo=1.0.0.11
UBIFS error (pid 0): ubifs_get_sb: cannot open "ubi:fs", error -19
UBIFS error (pid 0): ubifs_mount: Error reading superblock on volume 'ubi:fs' errno=-19!
ubifsmount - mount UBIFS volume
Usage:
ubifsmount <volume-name>
- mount 'volume-name' volume
UBIFS not mounted, use ubifs mount to mount volume first!
ubifsload - load file from an UBIFS filesystem
Usage:
ubifsload <addr> <filename> [bytes]
- load file 'filename' to address 'addr'
ERROR: can't get kernel image!
Saving Environment to SPI Flash...
Usage:
Usage:
ETH LINK UP: 1000FD
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
Retry count exceeded; starting again
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
- DaneANETGEAR Employee Retired
- AWENAAspirant
Thanks for the answer. But isn't there any instruction: how to restore software?
I read the NETGEAR CLI user manual, but did not find the information I needed, maybe I was looking in the wrong place?
- JosephITutor
I had the same problem and stumbled upon this thread. I had luck recovering from the same state by following the steps in my post here:
My method did require a TFTP server, but theoretically the other methods to transfer files should work too. I think my biggest hurdle was figuring out the proper load address which I finally got by printing the environment before issuing other commands. That got me to the operational code utility and then doing a "Load Code Update Package" restored the switch to an operational state for me.
