Orbi WiFi 7 RBE973
Reply
Does M4300 support DHCP Reservation or DHCP Static mapping?
JACK-THINK
Guide
I have a database which contains MAC and IP mappings. I want the built-in DHCP server to assign the designated IP address to the client with the specific MAC address in strict conformity with the database automatically. This function is called "DHCP-Static Mapping" on Cisco switches and it should behave like
https://www.cisco.com/c/en/us/td/docs/ios/12_2sb/12_2sba/feature/guide/sbhcpsm.html
. How can I configure the M4300 to load the database? Thanks a lot.
Plus, I have also tried "System-Services-DHCP Pool Configuration". And it turns out that I have to create ONE "manual_pool" for EACH MAC-IP mapping. It's REALLY tedious and boring. Is there any convenient way to load an external text-based database? Thanks a lot.
Model: XSM4324S|M4300-12X12F - Stackable Managed Switch with 24x10G including 12x10GBASE-T and 12xSFP+ Layer 3
Message 1 of 6
Retired_Member
Not applicable
Re: Does M4300 support DHCP Reservation or DHCP Static mapping?
Hi @JACK-THINK
Welcome to Commuity!
Currently, M4300 not support this function. For DHCP Reservation, just as you said, only support one "manual_pool" for EACH MAC-IP mapping.
Eric
Message 2 of 6
JACK-THINK
Guide
@Retired_Member
Thanks a lot for your reply.
As the core of LAN, L3 switch really needs DHCP reservation, which is indispensable. It would be great if the your developers can add this feature I stated above to M4300.
Message 3 of 6
Retired_Member
Not applicable
@JACK-THINK
One more question, how many DHCP-Static mapping table in your network? I will ask developer to estimate the feasibility for this feature.
Message 4 of 6
JACK-THINK
Guide
@Retired_Member
Thanks for your reply.
I use M4300-12X12F as an Access and Core Switch, only 20 clients are attached to it now. According to the datasheet of M4300(DHCP Server: 2K leases IPv4: 256 pools IPv6: 16 pools), the switch is capable of holding much more MAC-IP mappings than 20. I think it's appropriate to make the number of mappings equal to the number of physical ports on the switch at least.
Thanks a lot.
Message 5 of 6
Retired_Member
Not applicable
@JACK-THINK
Ok, got it.
Thanks for your detailed information.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2827 views
  • 0 kudos
  • 2 in conversation
Announcements
