hoobaman
Nov 16, 2011Aspirant
FSM7328S hardware(?)/firmware issue
I just bought this switch on Ebay. I am afraid that the reseller sold my a faulty unit and I would like to get an opinion of some experts here.
Initially the switch is unable to boot properly
Personally I suspect some kind of hardware issue, however I decided to upgrade the switch to the latest firmware.
Afterwards I tried several times to load the "FSM application" but it always gave me the following error
I was unable to get out this aplication load/boot loop so i did a hot reset of the switch ( reset button, no power down). From that moment on I only see uboot loading but the autoboot does not load anymore.
My questions:
-Does the first error point to a hardware faillure?
-Did I brik my switch when i tried to upgrade to the lastest version?
-Is there anyway to get out of this mess?
Any help would be appreciated as i am a netgear noob :)
U-Boot 0.3.0 (Feb 26 2006 - 15:25:00)
Board: Netgear FSM73xxS
DRAM: 128 MB
Flash: 16 MB
Hit any key to stop autoboot: 0
## Booting image at a0001000 ...
Image Name: Netgear FSM73xxS
Image Type: MIPS Linux Multi-File Image (gzip compressed)
Data Size: 2049347 Bytes = 1.10 MB
Load Address: 80200000
Entry Point: 8038a048
Contents:
Verifying Checksum ... OK
Uncompressing Multi-File Image ... OK
Starting kernel ...
FSM73xxS Startup Rev: 1.3
Select startup mode. If no selection is made within 3 seconds,
the FSM73xxS Application will start automatically...
1 - Start FSM73xxS Application
2 - Display Utility Menu
Select (1, 2): 2
Starting FSM73xxS application...
\soc_reg32_read: invalid S-Channel reply, expected READ_REG_ACK:
HDR[CPU=0 COS=0 EBIT=0 ECODE=0 L=4 SRC=15 DST=15 OP=14=WRITE_REG_ACK]
DW[ 0]=0x38f3c200 DW[ 1]=0x00000200
UNIT 0 SCHAN ERROR: V/E=1 SRC=32 DST=13 OPCODE=0(UNKNOWN_OPCODE) ERRCODE=0x23
|soc_schan_op: operation timed out
HDR[CPU=0 COS=0 EBIT=0 ECODE=0 L=4 SRC=15 DST=0 OP=11=READ_REG_CMD]
DW[ 0]=0x2c03c200 DW[ 1]=0x00a80002
UNIT 0 SCHAN ERROR: V/E=1 SRC=32 DST=10 OPCODE=0(UNKNOWN_OPCODE) ERRCODE=0x2
-soc_schan_op: operation timed out
HDR[CPU=0 COS=0 EBIT=0 ECODE=0 L=4 SRC=15 DST=0 OP=13=WRITE_REG_CMD]
DW[ 0]=0x3403c200 DW[ 1]=0x00a80002 DW[ 2]=0x101ae9b1
\soc_schan_op: operation timed out
DW[ 0]=0x3403c200 DW[ 1]=0x00a80002 DW[ 2]=0x101ae9b0
UNIT 0 SCHAN ERROR: V/E=1 SRC=32 DST=14 OPCODE=0(UNKNOWN_OPCODE) ERRCODE=0x20
DW[ 0]=0x2c03c200 DW[ 1]=0x00e800a0
system_init: Misc init failed: Operation timed out
UNIT 0 SCHAN ERROR: V/E=1 SRC=32 DST=14 OPCODE=0(UNKNOWN_OPCODE) ERRCODE=0x21
/soc_schan_op: operation timed out
DW[ 0]=0x2c03c200 DW[ 1]=0x00e800a1
DW[ 0]=0x3403c200 DW[ 1]=0x00e800a1 DW[ 2]=0x011aa001
Platform resetting ...
The system is going down NOW !!
Sending SIGTERM to all processes.
FSM73xxS Startup -- Utility Menu
2 - Load Stack Code Update Package using XMODEM/YMODEM/ZMODEM
3 - Display Vital Product Data
4 - Select Serial Speed
5 - Retrieve Error Log using XMODEM/YMODEM/ZMODEM
6 - Erase Current Configuration
7 - Erase Permanent Storage
Q - Quit from FSM73xxS Startup
Select option (1-8 or Q): 2
Select Mode of Transfer (Press X/Y/Z for XMODEM/YMODEM/ZMODEM): Y
Do you want to continue? Press(Y/N): y
Ready to receive file via YMODEM
Please start YMODEM sender before the receiver times out
rb waiting to receive.C/
Check the code version
116+0 records in
116+0 records out
Code version is 07.03.01.07
77631+1 records in
77631+1 records out
Extracting components. Please wait...
Extracting pSystem...
Extracting u-boot.bin...
Extracting rootcert.pem...
Extracting server.pem...
Extracting dh512.pem...
Extracting dh1024.pem...
Done.
Select option (1-8 or Q): 1
LVL7 SIGSEGV Handler
Warning!!! an error occured while handling a SIGSEGV
Note: The most likely cause of this error was stack corruption
in or about the last stackframe in the file.
Starting pid 301, console /dev/ttyS0: '/etc/rc.d/rc.fastpath'
Mount failed!
Crash information files detected!
U-Boot 0.3.0 (Oct 2 2007 - 16:15:57)
DRAM: 128 MB
Flash: 16 MB
My questions:
- jmizoguchiVirtuoso
DRAM: 128 MB
Flash: 16 MB
if you are stuck just this information and stop booting then unit is faulty - hoobamanAspirantThanks for your reply jmizoguchi's
A question that is still haunting me, was the unit already faulty before I did the upgrade or did I brik the switch with the upgrade? - jmizoguchiVirtuosoProbably bad NVRAM , hardware issues.
- hoobamanAspirantThanks for your support. I really appreciate it
- jmizoguchiVirtuosoUsually this happens when NVRAM is fault and during the writing the file it shows symptoms like that.
I had my FSMxx quit with like you had seen with few boot up information
