Radio_bahrain
Dec 28, 2020Follower
Ping Issue
Hi
I am using GS724T switches. Problem i am facing is that entire switch is in one single vlan, when laptops and computers are connected, each of them can ping while when i connect a an encoder it doesnt pings.
These encoders when connected through a cisco switch are reachable and ping as well.
Kindly suggest as i have 2 of these switches.
1 Reply
- JohnC_VNETGEAR Employee Retired
Welcome to our community! :)
It seems that you are having issues once the encoder is connected to the switch. May I know the exact model of your encoder? Have you checked the IP address of the encoder if it conflicts to any of the devices connected in your network?
John
NETGEAR Community Team
