user_786
Aug 30, 2024Follower
compatible SFP modules for M430012x12F
Hello Everyone,
its my first post on this forum. I ma trying to configure netgear M4300 12x12F switch with copper and fiber SFP's below are the details:
Copper: FS SFP10G-T 10GBASE-T SFP= 30 m
Fiber: FS SFP 10GSR-85
10G SFP+ 850nm 300 m
Under Monitoring Cable Test section , these ports are showing as invalid cable type , although cable is connected via SFP copper port and device is being accessed via the same cable.
can you please guide us which SFP(Copper and fiber) are compatible with M4300 12x12F network switch.
1 Reply
https://www.netgear.com/business/wired/switches/accessories/
All Netgear 1G SFP and 10G SFP+ modules versions are supported. See M4300 series Data Sheet p.28 ff.
Third party modules might be workable, but are not supported.
Cable test is workable on built-in transceivers AFAIK. LaurentMa svp.
