MarkSch
Jul 15, 2019Follower
sfp tranceiver for GS724TPv2
HI
I need confirmation on which sfp tranceiver modules to buy?
All ready bought:
2 x NETGEAR GS724TPv2 - Switch - smart - 24 x 10/100/1000 (PoE+) + 2 x 1000Base-X SFP (uplink) - rack-mountable - PoE+ (190 W)
2 x C2G LC-LC 10Gb 50/125 OM3 Duplex Multimode PVC Fiber Optic Cable (LSZH) - Network cable - LC multi-mode (M) to LC multi-mode (M) - 3 m - fibre optic - 50 / 125 micron - OM3 - halogen-free - aqua
I was thinking of purchasing:
NETGEAR ProSafe AGM731F SFP (mini-GBIC) transceiver module GigE 1000Base-SX LC multi-mode for NETGEAR M4300-28G-PoE+
Thank you
Mark
Model: AGM731F|1000Base-SX GBIC w/ LC Connector, GS724TPv2|24-Port Gigabit Ethernet PoE+ Smart Managed Pro Switch with 2 SFP Ports
1 Reply
- DaneANETGEAR Employee Retired
The AGM731F is compatible to both the M4300-28G-PoE+ and the GS724TPv2. As reference, kindly check the following data sheets below:
M4300 Series Data Sheet - see page 25
GS724TPv2 Data Sheet - see page 9
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
