- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
LED Lights out GS105
- Mark as New
- Bookmark
- Subscribe
- Permalink
ProSafe GS105
All the LED lifghts excep the one showing power are out. None of the devices connected to the switch are working. Interestingly when one device stopped working I switched the ethernet cable to see if that was the problem. When I plugged the new cable in the LED lights did not come back on all the other lights were on but nothing worked. As I unpligged each device the lights went out and did not come back on. Tried restarting the switch, did not help. I installed it in May 2016 and it has worked OK since then. Cannot find a place on NetGear to deal with this under warranty everywhere seems to want one to sign up for and pay for technical support but I think My Unit has died. Would apprecite any input.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: LED Lights out GS105
Hi MitchBVI,
Thank you for posting in the community. I wanted to check have you tried using a different power supply on the device?
Please let me know. :]
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
D you mean a diferent plug not sure if Ihave another NG block
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi MitchBVI,
Thank you for your response. Yes, I meant a different plug as in another power cable. This can tell us if its the cable or the actual device.
- Jason N
