- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk M1 battery charging problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk M1 battery charging problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
I managed to get full 100% charge after complete discharge/recharge cycle which took some time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I have experienced this before, but now issue came back again, battery charge again 97%.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is possible to display 86 lines of information about M1's battery and charging which clearly indicates that Netgear takes product safety considering battery very seriously.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The industry has learned lessons from Samsung Galaxy Note 7 battery fiasco and manufacturers do not take any risks with Li-ion batteries. So with enough data from battery and charging process makes possible precise software control.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
For best battery performance, life and safety, charging sequence cannot work anyhow. It has to work perfectly. This is not the situation right now, but Netgear has tools to fix the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you describe how you have your MR1100 setup, how devices are connected and in what type of environment are you using the device in? i.e. Do you have device connected to WiFi only or is there devices connected to Ethernet port and USB port as well. Do you have SD card inserted in your MR1100? Also when the MR1100 battery reached certain temperature it will stop charging for safety reason? Can you provide the screenshot of the battery and device temperature when you see the battery 97% charged? (You can find this on the same page where the battery charging level is displayed). It is possible that when you battery reaches 97% that it gets too hot to charge thus cutting the charging off?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Today I have tested a Netgear solution for this problem and it worked well.
It is device parameter thing, BatLevRechgNorm parameter has to be changed from value 99 to 96, then battery charge is back to 100%. This fix will be included into next firmware release.
- Mark as New
- Bookmark
- Subscribe
- Permalink
is there an ETA on this firmware? Will it also correct the non-charging issue where the devices will not charge if they are at 44 degrees?
My device is used heavily and it seldom charges full. My battery is typically completely dead. I have also tried other QC3.0 supported chargers. Nothing seems to help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do not know when next FW is coming out.
Temperature limits:
BatCritTemp - 57
BatHotTemp - 45
BatColdTemp - 1
If battery is hot it is quite obvious that it affects charging. It is better be careful with Li-ion batteries.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i was able to resolve my charging issues. I simply set the nighthawk upside down on my desk with the back cover off. it now stays completely cool. I may try and build some type of heatsink for this or 3d print some type of solution, as it seems to clearly be tied to temps as it has maintained a full battery charge for the past week.
- Mark as New
- Bookmark
- Subscribe
- Permalink
While I agree it's better to be safe than sorry with regard to Lithium Ion battery safety. It seems the MR1100 is overly conservative. My iphone can get warm, even hot in my hand while charging, as do several of my Anker batteries. The MR1100 seems very fussy with regard to temp, if the battery is even the slightest bit above room temperature it often won't change unless I open the back and let it air out.
I wonder if the thermisters which are used to measure the temperature either aren't placed in a good spot or are not well calibrated.
-Jonathan
- Mark as New
- Bookmark
- Subscribe
- Permalink
mine has been running over a week flipped over with the cover off, with the same or more usage as before and it is significantly cooler. it has ZERO issue holding a charge now.
I wonder if i could just drill vent holes into the battery cover to help it breath. the whole thing is sealed up with no venting. it seems to be a design flaw if it needs to actually breath - no wonder if it overheating.
