wuzcsg
Oct 11, 2020Tutor
How to turn off Netgear Armor?
Hi,
My model is Nighthawk RAX20 Dual-band AX4 WiFi 6 Router - AX1800 and I just changed from Google Wifi.
After changed the RAX20 I found something strange.
- I can't turn off the Netgear Armor.
I know it's in the admin app but no matter how I tried, it always showed: "Disabling NETGEASR Armor.", then "Process is taking too long (more than 60 secs) Try again!!"... Really no words, such bad user experince. - I used speedtest to test, before Google Wifi was always around 600-700Mbps (download), but now I only got 100-130Mbps..., are you kidding me??
Does anyone can advise?
Thanks
James
Armor has its own bolt hole:
NETGEAR Armor - NETGEAR Communities
You might like to try there too.
The rest of your message is a bit hard to follow.
Visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.Greetings,
How to turn it off:
You can also do it in the router's GUI itself.
How to cancel it:
https://kb.netgear.com/000059446/How-do-I-cancel-my-NETGEAR-Armor-subscription
Which will ultimately lead you here...
- Christian_RNETGEAR Employee Retired
Hello wuzcsg,
May you refer to the articles provided by shadowsports and let me know if your issue persists. You may also try reinstalling the Nighthawk app and power cycling your router.
Christian
- wuzcsgTutor
The only way to turn off was factory reset and turn off in the very begining...
