tks-it
Nov 10, 2022Aspirant
Insight is not reachable
Hi there,
I was wondering if anyone has problems with connecting to Insight Cloud Portal. I can log in but it always pops up with an error that Insight is not reachable at the moment... this is doing for at least two hours for now...
- DaneANETGEAR Employee Retired
We apologize for the inconvenience this has caused you. 😞
This is currently being fixed.
DaneA
NETGEAR Community Team
- tks-itAspirant
Thank you very much. I just started to change SSIDs, rules and passwords ... and then kaboom 😄
Thanks for the reply.
Just an update. The issue is now resolved. If you encounter any problems, kindly try to log out then log back in.
If in case the problem still occurs, I suggest you to open a support ticket with the NETGEAR Support Team here at anytime for further assistance.
DaneA
