Orbi WiFi 7 RBE973
Reply
RBR750 - How to manage parental controls subscription
Hathaway9
Tutor
So...  I've signed up for a year of parental controls but can't seem to find where I manage the subscription on the netgear site.   Can anyone point me in the right direction?
Thanks
Message 1 of 9
Accepted Solutions
Guru
Re: RBR750 - How to manage parental controls subscription
Click on "add ons"
Message 5 of 9
All Replies
Guru
Its done through the app.
open the app and click on the upper left home icon.
Then click on "my subscriptions"
Message 2 of 9
Hathaway9
Tutor
I don't have an option on the app for subscriptions.    I assume you're referring to the Orbi app that I use to maintain my router and everything.   Account management, support and profile options from the home menu don't show anything useful either.   I want to change my setting to not auto-renew but it doesn't seem to show me how to control that.
Message 3 of 9
Hathaway9
Tutor
see attached screenshot for my home menu  options
Message 4 of 9
Guru
Click on "add ons"
Message 5 of 9
Hathaway9
Tutor
Thank you!    Found it under "Add Ons" like you said.    Many thanks
Message 6 of 9
Guru
Glad it worked!
newer version of the app have it under the my subscriptions.
Message 7 of 9
fargozhu
Tutor
I don’t have the add-ons option and my router is running the latest firmware 4.6.5.14
Any thoughts?
Message 8 of 9
Guru
Are you subscribed to parental controls and is it running?
Then it should give you an option. In mine, if my parental controls/other add in's aren't running, it doesn't show the option.
If that doesn't help, please start your own thread so we're not confusing your details with the OP's
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2874 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
