falconyt's avatar
falconyt
4 pin din power supply replacement for RN104
Hello,
Recently picked up a used ReadyNAS RN104, the power supply adapter that has come with it doesn't stay in the ReadyNAS unless you really push it in. The ReadyNAS works fine however, I would like to get another power supply. Would a generic 4 pin din power supply with the same power specs work? or Does Netgear do something special with the pin outs on their connector?
Thanks.
  • Hi falconyt,
    Yes, a similar power supply with the same specs would do it. Pins or connector differ where the product was released or being sold.
    Kind regards,
    BrianL
    NETGEAR Community Team
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi falconyt,
    Kind regards,
    BrianL
      • BrianL2's avatar
        BrianL2
        Hi falconyt,
        You're welcome! You may now tag this thread as resolved by clicking the accept as solution button from the response that you received.
        Kind regards,
        BrianL
ProSupport for Business
