dunkens's avatar
dunkens
Apprentice
Dec 29, 2019
405 method not allowed readynas 526
Hi
Trying to access the readynas shared folder via cyberduck alt netdrive , but it ends up with 405 method not allowed
Trying to mount a local drive via network path
Is there some special setting the readynas should be used ?
  • StephenB's avatar
    Are you doing this remotely (over the internet) or locally?
    I have no experience with either tool, but it looks like you'd need to use FTP or WebDav with Cyberduck.  Either way, you would need to enable the protocol for the NAS share, and you'd need port forwarding set up in your router to use either protocol remotely.
    • dunkens's avatar
      dunkens
      Apprentice
      Hi
      Its locally.
      Port 443 is open
      WebDav is enabled in the share aswell
      Any other idea why webdav aint working ?
      • StephenB's avatar
        dunkens wrote:
        Its locally.  WebDav is enabled in the share aswell
        No (it's not a protocol I use).  Does it work correctly with your browser?
ProSupport for Business
