jboroden's avatar
jboroden
Adding a drive to ReadyNAS 204 #26877295
I have a readyNAS 204 with 2 drives set as raid1, can I add a 3rd drive and use it as a separate drive?
  • anna_arun's avatar
    anna_arun
    NETGEAR Expert
    If you dont want the new drive in the same volume , switch off X-RAID and add the drive . You can create a new volume and use the drive .
    • BrianL2's avatar
      BrianL2
      NETGEAR Employee Retired
      Hi jboroden,
      Are you still having issues adding a new drive in your ReadyNAS system?
      Kind regards,
      BrianL
      NETGEAR Community Team
      • jboroden's avatar
        jboroden
        I am getting conflicting answers, some people say I can add a 3rd separate drive, and phone support said it was not possible?, I do not have confidence in the phone support as they had to keep passing me on to other people and it was very hard  to understand them (strong accent)
ProSupport for Business
