InterClaw
Feb 05, 2013Aspirant
How do I get dmidecode?
I want to check some details on the RAM in the NAS. I've seen dmidecode been mentioned. How do I get that on the ReadyNAS Pro 6?
- chirpaLuminaryI use it in my BIOS Update add-on. Easiest way to get it, you can install that add-on, and it will be left in /usr/sbin/dmidecode.
The add-on does no harm, if there is a BIOS available for your system board it will be updated, otherwise it exits.
http://www.readynas.com/download/addons ... .5-x86.bin
edit:
Or skip the add-on, and grab it directly:# wget --no-check-certificate "https://dl.dropbox.com/s/wcbf6kiry1le87o/dmidecode?dl=1"
# /usr/sbin/dmidecode
# dmidecode 2.8
SMBIOS 2.6 present.
17 structures occupying 1007 bytes.
Table at 0x000FBDD0.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: American Megatrends Inc.
Version: 080016
Release Date: 08/23/2011
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 2048 kB
Characteristics:
ISA is supported
PCI is supported
PNP is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 KB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Targeted content distribution is supported
BIOS Revision: 8.16
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: NETGEAR
Product Name: ReadyNAS
Version: 08/23/2011 ReadyNAS-NVX-V2 V1.10
Serial Number:
UUID:
Wake-up Type: Power Switch
SKU Number:
Family:
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Version:
Serial Number:
Asset Tag:
Features:
Board is a hosting board
Board is replaceable
Location In Chassis:
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 21 bytes
Chassis Information
Type: Desktop
Lock: Not Present
Version:
Serial Number:
Asset Tag:
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Heigth: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
Handle 0x0004, DMI type 4, 42 bytes
Processor Information
Socket Designation: CPU 1
Type: Central Processor
Family: <OUT OF SPEC>
Manufacturer: Intel
ID: CA 06 01 00 FF FB EB BF
Version: Intel(R) Atom(TM) CPU D410 @ 1.66GHz
Voltage: 1.2 V
External Clock: 167 MHz
Max Speed: 1750 MHz
Current Speed: 1666 MHz
Status: Populated, Enabled
Upgrade: <OUT OF SPEC>
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: Not Provided
Serial Number: To Be Filled By O.E.M.
Asset Tag: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1-Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 24 KB
Maximum Size: 24 KB
Supported SRAM Types:
Other
Installed SRAM Type: Other
Speed: Unknown
Error Correction Type: Parity
System Type: Data
Associativity: Other
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2-Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 512 KB
Maximum Size: 512 KB
Other
Speed: Unknown
Error Correction Type: Single-bit ECC
System Type: Unified
Associativity: 8-way Set-associative
Handle 0x0007, DMI type 13, 22 bytes
BIOS Language Information
Installable Languages: 1
en|US|iso8859-1
Currently Installed Language: en|US|iso8859-1
Handle 0x0008, DMI type 15, 35 bytes
System Event Log
Area Length: 4 bytes
Header Start Offset: 0x0000
Header Length: 2 bytes
Data Start Offset: 0x0002
Access Method: Indexed I/O, one 16-bit index port, one 8-bit data port
Access Address: Index 0x046A, Data 0x046C
Status: Invalid, Not Full
Change Token: 0x00000000
Header Format: No Header
Supported Log Type Descriptors: 6
Descriptor 1: End of log
Data Format 1: OEM-specific
Descriptor 2: End of log
Data Format 2: OEM-specific
Descriptor 3: End of log
Data Format 3: OEM-specific
Descriptor 4: End of log
Data Format 4: OEM-specific
Descriptor 5: End of log
Data Format 5: OEM-specific
Descriptor 6: End of log
Data Format 6: OEM-specific
Handle 0x0009, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 2 GB
Error Information Handle: Not Provided
Number Of Devices: 1
Handle 0x000A, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x000FFFFFFFF
Range Size: 4 GB
Physical Array Handle: 0x0009
Partition Width: 0
Handle 0x000B, DMI type 17, 28 bytes
Memory Device
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM0
Bank Locator: BANK0
Type: DDR2
Type Detail: Synchronous
Speed: 667 MHz (1.5 ns)
Manufacturer:
Serial Number: 00000000
Asset Tag:
Part Number: PSD24G6672S
Handle 0x000C, DMI type 20, 19 bytes
Memory Device Mapped Address
Range Size: 4 GB
Physical Device Handle: 0x000B
Memory Array Mapped Address Handle: 0x000A
Partition Row Position: 1
Interleaved Data Depth: 1
Handle 0x000D, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x000E, DMI type 41, 11 bytes
Unknown Type
Header and Data:
29 0B 0E 00 01 83 00 FF FF FF FF
Strings:
Handle 0x000F, DMI type 41, 11 bytes
Unknown Type
Header and Data:
29 0B 0F 00 01 04 00 FF FF FF FF
Strings:
Handle 0x0010, DMI type 127, 4 bytes
End Of Table - InterClawAspirantSounds great! Will definitely try this out.
Just a couple of questions first though:
1. I can't find any info on this add-on on the site. Can you direct me to it?
2. Would this version be compatible with the Pro Pioneer as well? - mdgm-ntgrNETGEAR Employee Retired1. The add-on includes BIOS updates for some ReadyNAS models. BIOS updates can be needed for a variety of reasons for different models.
2. There is no BIOS update available for your model. The add-on should detect that if you tried to install it.
Edit: 2. Yes, the Pro Pioneer/BE, Ultra 6 Plus and Pro 6 use the same BIOS - InterClawAspirantOkay, thanks for the info.
I tried it on the Pro 6 and it gave me two prompts like such:
BIOS update encountered an error.
and then
The BIOS_Update_Package add-on has been successfully installed.
After that I could find dmidecode in /usr/sbin/dmidecode like you said. However, i was not able to get a speed reading off of the memory modules. Any idea why that might be? Is there any other way of determining the speed of them?
The reason I'm messing around with this is I had a 2x1GB kit of this memory lying around and after realizing the Pro 6 actually uses regular 240 pin SDRAM I decided to give them a go.
http://www.corsair.com/vs2gbkit667d2.html#tab5
They are rated at 667MHz and 5-5-5-15, but the speed says "unknown" and frontview says 4-5-5-15, so I'm curious what settings are actually used. Does the BIOS run them at 667 or 800 or does it go by the SPD always? If so, why 4-5-5-15? Is it actually overclocking them? :) They ran through the memory test fine though. I wanted to compare them with the one Apacer 800MHz stick that came with the NAS.
The chipset supports dual channel mode, so will two sticks put a lot of pressure on the memory controller you think? Will the heatsink be fine?
If this works fine I was thinking of going for a 2x2GB kit at 800MHz CL5 (which are still readily available) just to get some more headroom.
I know changing the RAM is not officially supported, but I'm just trying to figure what the BIOS is doing and what settings are being used, thanks!
