haupin's avatar
haupin
Memory upgrade for ReadyNAS Pro 6 Pioneer & Ultra
Hi.
I've got a ReadyNAS Pro Pioneer that keeps hanging at random points during resync, rendering it useless as it'll fail anywhere between 5 minutes and 5 hours after booting. I read in a different post that upgrading the memory will help.
I'm looking at different modules to buy now, and I'm not sure if I want to go for ECC or non-ECC. I'm thinking ECC would be good for a NAS, but if it's designed not to use ECC it might not be so good after all. Any thoughts?
Thanks.
  • Yes, I know it's not supported, yet there's a category with hundreds of posts on the forum, so people are still doing it.
    It's most likely a memory failure, the reason I have the second NAS is I bought it to copy over everything from this failing NAS with other discs, as I suspected the resync failure was caused by bad disks. It was stable with the disk out, and I copied everything over and bought new disks for this failing NAS, but now I have the exact same problem with new disks. The old disks are running fine in another computer now.
    So my question remains; if I want to replace my memory, can I use ECC or not?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    The Pro Pioneer is covered by a 3 year warranty. So I'd suggest testing the memory and if it's bad contact NetGear tech support with the results.
    Back in the days when memory upgrades were supported a Jedi said that only non-ECC modules were supported.
    NetGear had to remove the compatibility list for memory as new incompatible revisions of memory modules were introduced but with the same module number.
ProSupport for Business
