hnrkndr's avatar
hnrkndr
NAS212 : disk full, but stored data is much less than capacity
Hi!
Newbie question about capacity of NAS212 with 2x 4TB, RAID1:
Approaching 100% full disks, I have removed data (moved files back to the PC) from the NAS This cleared hundreds of GB, but after a few minutes, the NAS was choking full again.
The sum of stored files is waaay less than the anticipated capacity. I don`t understand what is going on. Which settings or actions do you recommend to re-gain more storage space?
Your time is much appreciated!!
P.S.:
1. I have run a scrub and balance, but not yet the de-fregment tool (disk is too full to complete?)
2. I am going to purchase a 2nd hand RN214 4x3TG for immediate storage expansion, but I would still like to understand the above posted problem.
3. I could post the system log, if that helps?
  • It might be simplest to delete the volume, recreate it and the shares, and then move everything back.
  • StephenB's avatar
    • Sandshark's avatar
      Sandshark
      Sensei
      How much is in home folders?  The GUI doesn't show usage there.  Do you have any ISCSI targets?
      • hnrkndr's avatar
        hnrkndr
        Ohhhh! On the home drive, I found are hundred of folders with thousands of copies of previously deleted desktop files!!!
        Thanks for pointing me at this discovery 😉
        The NAS seems to make timestamped copies of every file that once was placed on the desktop.
        FYI, I use the PC desktop daily in my workflow as a temporary holding bay for up/downloaded files.
        With 5 minutes of deleting some of these old temp files, I have gained substantial free space.
        Thanks for your help 🙂
        FYI, I do not use the "home" folders" for deliberate data storage at all; instead I have all my storage arranged in named shares.
ProSupport for Business
