- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN10200 not connecting to sagemcom f@st 5366
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN10200 not connecting to sagemcom f@st 5366
Are you sure the ethernet ports in the sagemcom work? (are you able to test them with another device?).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Benpar wrote:
Yes, i have a security camera system that is working and i have confirmed it works in every port
Ok.
Have you tried both ethernet ports on the NAS?
It might be worth seeing if RAIDar can find the NAS. https://kb.netgear.com/20684/ReadyNAS-Downloads Sometimes the NAS is connected properly to ethernet, but isn't getting a DHCP address.
Do you have a switch you can put in between the NAS and the router? If the router has "green ethernet" features, then it is conceivable that is interfering with the ethernet autonegotiation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAIDar does not find the NAS.
I don’t have a switch, but will try as soon as I can.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Benpar wrote:
There is only one ethernet port on the RN10200.
My bad, of course you are correct. For some reason I was thinking an RN202/RN212.
Maybe also directly connect the RN102 to the ethernet port of a PC, and confirm that that link lights are lit.
If that works and you use wifi on that PC to reach the internet, you could regain access to the NAS files on that PC by assigning an appropriate static address to the PC's ethernet port.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your help
