leahcimd1's avatar
leahcimd1
Apprentice
Oct 27, 2021
RN214 Bleeping Noise
Model: RN214
Firmware: 6.10.5
Hi,
I have noticed recently that my RN214 is making a faint bleeping noise, but noticeable enough to be annoying.
I thought at first it was coming from my PC, but I have narrowed it down to the RN214.
It appears to be in time with data write operations, and occurs cyclicly in between the flashing of the data LEDs.
I've only noticed it over the last few days, but it's not a constant occurrance, in fact as I type this it has just stopped, but data is still being written.
Thanks in advance for any ideas.
1 Reply
  • StephenB's avatar
    The NAS has no speaker.  This noise is coming from one of the disks - and the noise means that the drive is failing and needs to be replaced (even if it passes the diagnostics).  If the disk is still covered by warranty, the vendor will replace it with a recertified disk.
    It can be hard to figure out which disk is making the noise.  One method is to power down the NAS, and connect each disk to a Windows PC using either SATA or a USB/adapter dock.  Label the drives as you remove them (so you can return them to the correct slot later).  Use the long generic test in the vendor tools (Seatools for Seagate; Lifeguard or Dashboard for Western Digital).  That should let you isolate the failing drive.
    When done, put the drives back in the NAS (leaving out the failing one), and power it back on.
ProSupport for Business
