leeado's avatar
leeado
RN314 - Fan issues
I powered on my NAS today and I get errors with the fan:
"Fan system is not working" on front page.
No matter which fan profile I choose, it seems to be running at 100% and is quite loud.
I tried disassembling and cleaning the fan.
Any pointers to get my fan back to "quiet"?
"Performance" tab says the fan is at 0 RPM, where is it clearly much higher than that!
Thanks for you help.
  • JeraldM's avatar
    JeraldM
    NETGEAR Employee Retired
    leeado
    Welcome to the community!
    Were there any events that may have caused the issue like a power outage?
    If possible, kindly PM me the logs to further check on this.
    JeraldM
    NETGEAR Community Team
    • leeado's avatar
      leeado
      Hi, thanks for your response!
      I have my NAS on a regular daily power cycle, so it shuts down every day.
      The only change I recall recently is setting a static IP as I was having DHCP issues.
      Which logs in particular would you like to see?  I would be uncomfortable sending the full set as it gives up too much personal information.
      Again thanks!
      • Sandshark's avatar
        Sandshark
        Sensei
        The tachometer signal from the fan is obviously not working.  That could be the circuit on the NAS, the fan, or even just a bad connection (unlikely unless you did some disassembly).  Assuming you've checked for a bad connection, replacing the fan is the only option, since the motherboard is not repairable.  I'm not familiar with what fan type is in the 314, so you'll have to take a look at the old one to see what you need for a replacement.
    • JeraldM's avatar
      JeraldM
      Hi leeado,
      Understood, if possible, please PM me the hwmon.log, services.conf, and the status.log.
      It's most likely that the issue would be the hardware (as suggested by Sandshark) instead of its software.
      JeraldM
ProSupport for Business
