vestry's avatar
vestry
ReadyNAS 104 tray/caddy
Does anyone know where I can get a tray/caddy for a RN104? I saw the links in a similar post some months back but they lead to items that are out of stock with an unknown availability date which isn't helpful. Does anyone have a spare they no longer need?
    • StephenB's avatar
      Note that older desktop ReadyNAS trays will also work in the OS-6 NAS (though the new trays won't fit the old NAS).  So you could get an older tray (either stand-alone as getting an old used NAS).  The older trays with the round latches tend to stick, so you'd be better off getting the older ones with the square latches.
      Why do you need another tray?
      • vestry's avatar
        vestry
        Thanks - yes, but I don't seem to be able to find a tray with a square latch (or, in fact, a round one) at the moment. I need one because the 104 I got only came with 3 trays. I'm guessing when the old NAS units die the owners don't bother to sell off the parts.
    • vestry's avatar
      vestry
      Many thanks for the suggestion and that these trays are compatible, but this seems expensive (to me!) for just a single tray. It seems strange that Netgear makes these things but doesn't seem to stock parts.
ProSupport for Business
