Orbi WiFi 7 RBE973
Reply
ReadyNAS 212 won't upgrade or install apps! Help!
Snowman8
Tutor
I have the ReadyNAS 212 with firmware 6.9.4 Hotfix 1.  When I click "check for updates" it says a new version 6.10.2 is available, but when I click "Update".  I get the error 6001010056.  I have tried to cloud update with no luck.  I have downloaded the arm version of the firmware and tried to update manually but get the error "file is missing or corrupt".
I also tried to install Plex Media Server (for RN2xx) from the admin interface and via the manual download and upload but this has failed also.
Any help is appreciated!
Model: RN21200|ReadyNAS 212 Series 2- Bay (Diskless)
Message 1 of 10
Accepted Solutions
JohnCM_S
NETGEAR Employee Retired
Re: ReadyNAS 212 won't upgrade or install apps! Help!
Hi Snowman8,
The issue could be network related. There might be a network filter that is going on or something.
We are getting "hash sum" errors when trying to check for updates. We also tried downloading Plex and it is the same.
The NAS cannot successfully download the deb file from the server itself for whatever reason, but when we go to manually install it, we have to get dependencies and they have a similar problem. It is almost like network traffic being intercepted.
Message 9 of 10
All Replies
Sandshark
Sensei
Maybe obvious, but did you use just the .img file from the zip, not try to upload the whole zip to the NAS for the local update?
Message 2 of 10
Snowman8
Tutor
Hello Sandshark,
Thank you for the suggestion, yes I have upload the .img file.
I have also tried to reboot the NAS and turned off the anti-virus.  Still NO LUCK!
Message 3 of 10
Sandshark
Sensei
A too full OS partition can cause problems like that.  Have you seen any warnings about that in the log?
Clearing the browser cache or even switching to another browser can sometimes make a difference.
Message 4 of 10
Snowman8
Tutor
Running RAID 1 with 2.4 TB of free space.  I don't see any errors in the log.  I did download all the logs is there a specific file I should look into?  I have cleared the cache and have used both Firefox and Chrome browsers, with no success.
Message 5 of 10
Guru
Take a look at volume.log Scroll down to the === df -h === section and tell us how much free space there is in /dev/md0.
Also a bit lower down there is a === df -i === and let us know the IUse%
Message 6 of 10
Snowman8
Tutor
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 3.7G 1.1G 2.5G 31% /
tmpfs 1009M 0 1009M 0% /dev/shm
tmpfs 1009M 6.8M 1003M 1% /run
tmpfs 505M 940K 504M 1% /run/lock
tmpfs 1009M 0 1009M 0% /sys/fs/cgroup
/dev/md127 5.5T 3.1T 2.4T 57% /data
/dev/md127 5.5T 3.1T 2.4T 57% /apps
/dev/md127 5.5T 3.1T 2.4T 57% /home
=== df -i ===
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 187946 228 187718 1% /dev
/dev/md0 1048576 12274 1036302 2% /
tmpfs 188827 1 188826 1% /dev/shm
tmpfs 188827 434 188393 1% /run
tmpfs 188827 21 188806 1% /run/lock
tmpfs 188827 9 188818 1% /sys/fs/cgroup
/dev/md127 0 0 0 - /data
/dev/md127 0 0 0 - /apps
/dev/md127 0 0 0 - /home
Message 7 of 10
Guru
@Snowman8 wrote:
=== df -h ===
=== df -i ===
This says it's not a full OS partition.
I suggest putting the full log zip file into cloud storage (google drive, dropbox, etc), and then sending a downloadable link to one of the mods ( @JohnCM_S or @Marc_V ) and ask them to analyze it.  Send it via Private Message (PM), by clicking on the envelope link the the upper right of the forum page.
Message 8 of 10
JohnCM_S
Hi Snowman8,
Message 9 of 10
Snowman8
Tutor
A BIG thanks to @JohnCM_S!!  He narrowed the issue down to a network issue.
The NAS is connected to my Orbi router via two chained switches. After reading his message today indicating a possible network issue, I plugged the NAS into the the first switch skipping the second. I restarted the switch and it errored again. I rebooted the NAS and turned off anti-virus and it updated!!
I turned anti-virus back on. I tred to install the Plex server. It errored out. I turn off anti-virus and tried again with no success. I left the anti-virus off, rebooted and then I was able to install Plex server.  All is working great!
THANK YOU @JohnCM_S and @StephenB  for your assistance!
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3217 views
  • 2 kudos
  • 4 in conversation
Announcements
