spangle_it's avatar
spangle_it
Readynas 102 low disk space
HI
I am running out of  storage space and have plans to upgrade to a larger unit
As an immediate fix to get more space I have copied off old data to a USB drive  and deleted the data from the nas,
 However the free space has not increased, and still running out of space. I know from other NAS devices there is a recycle bin which needs to emptied after deleting files.
But I cannot find a recycle bin or any other means of reclaiming space from the deleted files.
any ideas?
Malcolm
  • StephenB's avatar
    If you have snapshots enabled, then go in and delete them.
    After you done that, then try running a balance (from the volume settings wheel).
    • Sandshark's avatar
      Sandshark
      Sensei
      OS6 does not have a recycle bin (though many have asked that that OS4.x feature be added).
ProSupport for Business
