PopeUnholio
Dec 21, 2018Follower
Readynas rn104 tray/caddy
Where can i purchase, or find a part number for a readynas rn104 tray/caddy. Unit isn't in warranty, so asking support where to purchase is a no-go. I'd be happy to purchase from netgear directly, I just need to know how/where to do so. I have 2 trays, the other 2 got lost in a move cross country.
Thanks
- Retired_Member
Hi PopeUnholio, found this on amazon. Comments say, that it works with rn104, too.
Kind regards
https://www.amazon.com/NETGEAR-Spare-Disk-Screws-Readynas/dp/B000W3T2UO
It should also work in the RN104 (though the OS-6 trays won't work in the older NAS).
The old trays with the round release latches do tend to stick, and I need to manually release mine with a paper clip. There was a newer version with square latches that are better. https://www.amazon.com/gp/offer-listing/B001N0BU1E/
Note these don't have mounting holes that are aligned with newer large capacity disks, but you still will find at least one pair of holes that will line up. They also weren't designed for 2.5" SSDs.
