Nigor's avatar
Nigor
Browser netgear genie v1.2.12 can't click simple or advanced tab
Hey there,
Since a few months now, I can't access advanced tab on my browser netgear genie because it's impossible to click on it, well, it highlights but the click doesn't load nor reacts.
I have tried disabling Adblock, using latest versions of Chrome, Firefox, tried using IE, still the same problem.
Do you have an idea how to bypass the problem ?
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi @Nigor,
    1. Have you tried using another device (another computer, smartphone, tablet)?
    2. Have you tried performing a power cycle (turning off then on)?
    3. Have you tried resetting the router?
    Dexter
    Community Team
    • Nigor's avatar
      Nigor
      Hi, I tried using my smartphone, who has the same issue with chrome and base android browser.
      The modem has been switched off and on multiple times, and even reset, I had to set the parameters (password and name).
      The issue is the same, without improvement. I'd like to try another (older) version of the router, but it seems like I can't install another version anyhow.
      Thanks for your attention.
