krb454's avatar
krb454
Guide
Jul 08, 2019
Enable Remote Mgmt Error
I am trying to enable Remote Management from the Nighthawk app and I'm receiving an error that says:
"Some error occurred while enabling/disabling remote managemnt"
I've rebooted, updated firmware etc. The Nighthawk app will not allow me to enable remote management.
  • michaelkenward's avatar
    michaelkenward
    Have you enabled Remote Management on the R8000P?
    There is support for the R8000P, including a manual and firmware, somewhere at the end of this link:
    >>>> R8000P | Product | Support | NETGEAR <<<<
    See the section Set Up Remote Management.
    • krb454's avatar
      krb454
      Guide
      If you are referring to the Remote Management setting through the web interface. Yes.It is enabled.
