ethernetping's avatar
ethernetping
High Variable Ping when using Ethernet ( MK83 / AX3600 )
Model: MK83 / AX3600
Firmware: V1.1.6.14_3.1.101 (I've tried rolling back firmware)
OS: Windows 10 and Windows 11, all computers really.
Environment where Relevant:  Most noticeable when playing games or voice chatting, but it is always happening.
The wifi works perfectly.  The ethernet ports do not.
I am getting horrible jitters when I play games.  I am NOT using wifi, I am plugged in to the main router.  My ping is insanely unstable.  When I ping my local IP in command prompt, I can see my ping spiking from <1 to over 80.  On rare occasions it goes over 200.  The router can't go 10 seconds without spiking over 2ms.  Plugging directly into the modem fixes this. (CM1200 Nighthawk modem).  I am using CAT 5e cables.
When me and my girlfriend both play together, its even worse.  We are both plugged in via ethernet, spiking to over 800 ping in Valorant.  We could both play perfectly fine on the old router and modem.
I'll provide screenshots below of my ping spiking in command prompt.
  • plemans's avatar
    what modem/gateway are you connected to?
    Does it happen if you hardwire the gaming console into the modem?
    • ethernetping's avatar
      ethernetping
      If I plug my laptop directly into the modem, it does not happen.  I am using a CM1200 Nighthawk Modem, using the first ethernet port.  My router is the only thing plugged in.  I am not using a console, just play on my laptop.
        ethernetping
        One of the worst tests I've run.  I've never seen an average of above <1ms on this test.
        I don't understand how my ping could be 155 when I am plugged in.
