highstream
Feb 21, 2016Aspirant
Can't access E6200
Yesteday I set up an EX6200 as an extender (or bridge) to a TP-Link AC1700 router via the WPS buttons for 2.4 and 5 GHz, then positioned the the unit where I want it. It shows on my Win 7 x64 laptop (wireless connections list). What I can't do is connect to it via wi-fi with mywifiext.net or 192.168.1.250 from a few feet away. This is my first time with an extender, so I'm not sure what to do next. Any ideas? Thanks,
- DarrenMSr. NETGEAR Moderator
Hello highstream
are you able to connect to it via ethernet?
DarrenM
- highstreamAspirant
Do you mean running an ethernet cable from the router to the EX6200?
I mean can you plug a pc into the EX6200 so you are able to get into the settings with mywifiext.com
DarrenM
