mkj3757
Jan 28, 2013Follower
Can't install
The instructions for this model tell you to go to http://mywifiext.net but that site no longer exists. The instructions also tells you to use a smart wizard but a search on their site doesn't turn it up. I did add the extender to my network successfully & password protected it but I have no clue what to do next. The instructions in the booklet that came with the extender are vague at best. The instructions on the internet are impossible to follow.
Can anyone help me?
I have a HP Touchsmart 320-1120m, Product# A5W91AV#ABA, Software Build# 12NA1ACW603#SABA#DABA, Service ID# 100-612.
MS Windows 7 Home Premium, Ver. 6.107601, SP1, x-64, Legation AAHD3-NK Motherboard, Processor AMD E2-3200 APU with AMD Radeon (tm) HD6370D Graphics DirectX 10 1600 X 900, Next Window Voltron Touch Screen, 2400 Mhz, 2 Cores, 2 Logical Processors, BIOS Ver. AMI 7.15 4/12//12, SMBIOS Ver. 2.7, 6GB RAM, Total Physical Memory 5.49 GB, Total Virtual Memory 13.7 GB, Page File Space 8.23 GB, Hitachi 3 Partition SATA Hard Drive 874GB Free, AMD SATA Controller RealTek PCIe GBE Family Controller, 802.11n Wireless LAN Card, MS Virtual WiFi Miniport Adaptor, NETGEAR Wireless Dual Band Router Model WNDR3400, Zoom 3.0 Modem Model 5341J Series 1094, HID HP Wireless ANATEL Keyboard Device, HP Standard Wireless HID-compliant Mouse, DVDRAM GT50N SATA cDRom Device, HP High Def 1MP Webcam Cyberlink Webcam Virtual Driver), Generic Pnp Monitor, IDT High Def Audio CODEC, Seagate Portable Backup Drive 1TB, DL Speed is 23.28 Mbps / UL Speed is .95 Mbps, IE 9, WLM Version 2012 (Build 16.4.3505.0912).
Can anyone help me?
1 Reply
- jmizoguchiVirtuoso
http://www.downloads.netgear.com/files/GDC/WN2500RP/WN2500G_IG_6Nov2012.pdf
You need try options 2 in the starting guide.
http://www.downloads.netgear.com/files/GDC/WN2500RP/WN2500RP_UM_9Nov12.pdf
page 9 , using ethernet cable to the extender
