NYPatti
Apr 26, 2020Aspirant
EX3700 EXTENDER WITH Apple Airport Express as router
I have my home WiFi via an Apple Airport Express(802.11n), on my MacMine running High Sierra10.13.6. I don't understand how to set up the extender, as I don't have means to wps on the airport express. Am I supposed to use Configure Other from Airport Utility and if so, what is the address and password? I read someone else's solution and I got lost. A little help would be appreciated.
Found a different work around--my iPhone liked NETGEAR_EXT
use the smart installationsetup proces from netgear. The support site has a video that walks you through it. I think its the 2nd video
https://www.netgear.com/support/product/EX3700.aspx
the manual also has the walk through as well.
- NYPattiAspirant
Watched video and still having issues because there is no place that shows NETGEAR_EXT on my computer
Is it supposed to show up on my Airport Utility as Other Wi Fi Device or is is supposed to be set up in System Preferences as a Wi-Fi network profile?
OR am I supposed to set it up in one of these places??
Not sure as its a mac.
the EX3700 does have an ethernet port you can hardwire in to do the setup. Just make sure to disable your wifi if your computer so its not defaulting back to the wifi during setup.
