Roboclock
Dec 21, 2018Aspirant
Extenders connected, but no internet
My Neighbor is letting me use his internet when I go south for 3 months. I run two cameras for security and some wifi outlets. I put an extender in his garage and It works, but the signal is weak and I can only connect on the wall of my house that faces his garage. So I added a second extender in my house so I would have signal thru out the house.
Had trouble getting it set up but finally got it, I had 15mbs in the house, I was so elated, Then next day came down and now I have nothing and can't seem to get anywhere.
I notoice that sometimes the signal gets weak from the extender in His house and I might loose connection in my house for and hour or so, Could the extender in my house be reconnecting diferently each time which is why once it worked and now it doesn't. The extender in His house it a TPlink, and I am on a Mac, and Iphone. I bought the Netgear ex6400 since it was said it would be more powerful, but the TPlink send a signal farther than the netgeat.
Any help would be appreciated, keep in minfd I am a novice
You'd want the extender in his garage to use a different network name than his router. Then you also want the extender in your home to use a different network name from the garage. That would prevent the extender in your home from trying to connect directly to the neighbor's router.
Also, 5Ghz has shorter range than 2.4 ghz. It might be simpler just to turn off the 5 Ghz radios, since the issue here is distance.
- RoboclockAspirant
To refresh I am using a neighbors internet to run security cameras while away from home . I dont have internet at the house, I use a hot spot which I take with me. I have two repeaters in series to cover the whole house. So as I continue to try to set this up I find I can get things working, one time I had a speed oif 15gbs tahts thru both repeaters, I was elated, But the next day i had no internet, went through set up several times and got things working okay agian. But.. next day no internet.
So it seems that things won't stay connected. It might be that I loose connection with the host from time to time and the extenders reconnect but the auto settings change, thus I loose connection down the line. I'm thinking I have to specifiy the different addresses in each repeater and noy have them change. Which fields are most criticle?
Did you try the suggestions I made above?
