Bravanboy
Dec 05, 2011Novice
How do I access the Menu in a WG602?
I'm using a Netgear RP614 Router connected via Virgin Media Cable Modem and then into the WG602 Access Point. I have a number of devices defined in the WAP from when I had a Windows PC (running XP). I now have an iMAC running OS X Snow Leopard. If I enter into the browser the address www.netgear.com I can access the menu of the Router. How do I access the menu of the WAP in order to edit the device list?
- jmizoguchiVirtuoso
www.netgear.com
there is not such domain to access the router interface
routerlogin.net is what router uses or simply IP of the devices with http://ip address - BravanboyNoviceYou're correct. I was v tired. The address to access the router menu is routerlogin.net (or .com), as you say. It won't get there via the IP address on the device. I still can't get to the WAP, attached to the router, even when I try to rest factory defaults on the WAP.
- jmizoguchiVirtuosoif you reset the unit there is default IP of the device
see manual to this model and there is specific on how to access the unit - BravanboyNoviceSORTED!
Thanks for the re-direct. I finally managed to find the correct route via the manual. Just needed to put the Static Address into the iMAC before connecting to and logging in to the WAP.
Thanks again.
Cheers! - jmizoguchiVirtuososounds good.. enjoy :)
