rtfarley
Oct 21, 2011Aspirant
WGR614v6 cannot connect two PC's
After relocating and returning to Comcast I can only have one PC connected to my router at a time. If I connect two, using cables, the router goes into a check cycle showing all indicator lites, then no lites, then flickering lites all within a fifteen second cycle before repeating. If I only connect one PC there is no problem. I'm guessing a address conflict but not sure and don't know what to do about it. Help!:confused:
- Check if your computers IP are set to static.
Check also on your router if "use router as DHCP server" box is checked. - rtfarleyAspirantThe NetGear smart wizard tells me that I am set to dynamic addressing and set to a DHCP client
- Try re-flashing the firmware and perform hardreset on router then run setup wizard.
- jmizoguchiVirtuosoGo ahead and reset the router first.
- rtfarleyAspirantWell, I re-flashed the firmware, did a hard reset and went through the setup wizard...no improvement. I even tried a different cable and different router port to no avail. Any suggestions?
- jmizoguchiVirtuosoPossible bad capacitor inside the router. Likely to be looking new router
- rtfarleyAspirantAre there any settings in Windows that could be causing a conflict? I recall having connectivity issues in Arizona (different ISP) and the man who lived nearby made some changes to the settings. I don't remember what he did though. Could have been to the static IP settings.
It is strange that when I plug in the cable for the second computer and the router goes into the cyclic check, the network status shows a cable is disconnected, ok, then disconnected as the router cycles.
Anyway, if you think a new router is needed, so be it.
Thanks to all for the help. - jmizoguchiVirtuosoIf there were IP conficit you will the error on pc.
- rtfarleyAspirantThe old router was the culprit afterall. Installed a new Netgear N300 today, took about five minutes, and all is working now.
Thanks everyone. - jmizoguchiVirtuososounds good ... enjoy
