Questioner
Jan 25, 2018Follower
WN2500 - can't connect via Ethernet
I need to connect my desktop PC to my WN2500 via wired Ethernet to access the settings, and hopefully to access internet also.
The WN2500 is working ok as a range extender when set up using a wifi connection. But when setting password for the extended wifi network, my browser tells me the connection is not secure and my data could be intercepted. I want to enter the extender's settings using a wired connection and web browser interface for better security. Also, I prefer to access the internet via the Ethernet ports.
I am connected to the internet through my landlord's wifi router and do not have access to the router settings. This is an application which I know is very common, but for some reason the extender manufacturers never discuss it in their marketing or support literature.
Thanks very much for any insights you can provide.
1 Reply
- DarrenMSr. NETGEAR Moderator
Have you updated the firmware on the unit?
DarrenM
