geneo
Sep 23, 2016Follower
want to use samsung s3 phones hot spot feature with netgear extender wn3000rp
i use my samsung galaxy s3 as hotspot for my computer, works fine. when i try to use netgear wn3000rp to extend my phones hotspot signal i can see the extender as an available wireless network connection with strong signal strengh on my PC but it won't connect. i run network trouble shooter and it says something about invalid IP address? can anyone help?
- DarrenMSr. NETGEAR Moderator
Hello geneo
Make sure you have the hotspot set to WPA2 security also you may need to do a factory reset on the extender and try to do the setup again.
DarrenM
- BelindaKAspirantI too trying to set up extender NW3000RPv3 to Samsung Galaxy s5. Extender says connected but not. What is the setup procedure? Maybe did something wrong
Hello BelindaK
Here is a KB with all of the setup guides for extenders.
http://kb.netgear.com/23517/Setting-up-NETGEAR-Wi-Fi-Range-Extenders?cid=wmt_netgear_organic
DarrenM
