Akonin's avatar
Akonin
Access control XR500 Duma OS
Ok..I can't find the Access control in my new XR500. I use Access control extensebly in my old netgear to keep everyone out from my wireless network to only that equipment I give permission.
I need to know where it is because I can't find it and that is a deal breaker for me and I might need to return the router.
Is there an access control for wireless in this router?
Thanks
  • As above it is not currently available. There is a sort of workaround that you could try, not sure if it will fit your needs or not but you can make a Traffic Controller rule to apply to ALL devices, then block at all times. You can then make individual rules for devices that you want to have internet access, as long as those individual rules are above the block rule they will supersede it and any new devices trying to connect that you haven't made an individual rule for will be blocked.
    • Akonin's avatar
      Akonin
      Thanks for the link.  It appears I bought a half baked router a beta one it appears.
      • FURRYe38's avatar
        The XR series is NOT half baked. Access controls were not a feature that was added by NG intended design. One reason is that the XR gaming routers are designed and focued with the gaming user in mind mostly. Gamers tend to want a good gaming routers with focus on gaming performances and gaming needs. Access Controls is more of a general router and paratal controls focus. This is seen on R and RAX and Orbi routers systems. If your not a gamer and want the access control features, then any gaming router would not be suitable for your needs. Try a R, RAX or Orbi system that supports access controls.
        Good Luck.
    • Akonin's avatar
      Akonin
      Thanks you very much for responding. I find access control necessary.  Everyday I find like 15 different equipment of all sort trying to connect to my router.  Acess control is like a second layer of security.  In my area is not just necessary but a security saver for my network.
      Thanks again I guess I'm returning the router unless I find another OS that can run in it.
