- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
COD BO4 Multiplayer Issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: COD BO4 Multiplayer Issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe I will ask ISP to replace it for new one.. I don't really know what else I can do....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
After the reset on the modem and set the modem for modem mode, see if this helps. If not, then I would recommend that you change out the modem for a newer stand alone modem with out a built in router and wifi, that your ISP supports and that you can buy. First see what they support and buy accordingly.
See if your ISP supports NGs CM 1000/1100 or Arris SB 6183 or SB8200 or Motorola MB 7420 or 8600. All these are stand alone cable modems. No router built in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I reseted my XR500, and My ISP Cable Netgear Modem. I set back Router Mode on ISP cable modem.
I can only play with one solution if I plug my Console into my ISP Cable modem (then Consile service workingm and any COD multiplayer also working properly). and any other tools are on my XR500, however it didn't make much sense to buy a professional game router.
I ask my ISP that he supports any other Cable Modem he said "no". That is all what I can do now. I still don't understand this situation. Anyway thank you (and everybody) for supporing me here...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry I have to correct what I wrote, When I plug my console into ISP Cable modem that set as No Router MOde, in this case the COD multi is working properly, but if I set my ISP modem for Router MOde the COD Multiplayer is n ot working again....
- Mark as New
- Bookmark
- Subscribe
- Permalink
My question is If I use my console plugged into ISP Netgear Cable Modem set as non router mode, is it safe?
I have checked in this case the NAT type and the game says is Strict, but I can play in multiplayer properly.
What should I ask from my ISP? How to solve this?
My aplologies for my massive questions but I can't play properly for three weeks, and my good gameing roter can't handle this ... 😞 I don't know what to do.. so sad..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is the true
"So the modem only works in modem mode not even router mode and you get get a strict NAT console direct in modem mode?"
I used my older router Netgear WNDr 3800, it was the same, not worked. And as I wrote that It only wroks if my ISP router modem is in non router mode, or using my mobile 4G as a hotspot.. no any other option
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the mfr and model of the ISP Modem?
Does this modem have a DMZ when in router mode?
Sounds like there is a problems at the ISP modem or ISP services...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 Yes, It has DMZ, but did not work regarding my game issue, when I put my console in .
C6250EMR Firmware Version
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
"Do you require PPPoE or anything to connect to the internet?" NO
Yep, FURRYe38 mentioned Cable Modems (NGs CM 1000/1100 or Arris SB 6183 or SB8200 or Motorola MB 7420 or 8600) I will try one of them... That could be an option... But I still do not understand what has changed so that COD servers are not available in the game, because I did not change anything.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I managed to borrow a cable modem (MB7420 16x4 Cable Modem), a little help went well but I have to say the situation is the same as before regarding Call of Duty (all) multiplayer online services.
Symptom is the same. Every games run perfectly in online except all COD, I had a conversation with Activision , I asked them to confirm that again I am not banned, I am not banned , never been, I have checked my profiles , everything is OK with that.
I can still run any COD in only one case: if I put the console directly on the cable modem, and I set the cable modem into "NON Router" mode, but there is a strange thing I see not OPEN NAT but STRICT, and yet the multiplayer is moving..
I saw something about PEA mode that ISP may know and set, but my ISP completely refused and said they check everything, all the ports are open, they can't have\see any problems..
This is a really unique problem, I know , but the family has been playing this game for years.... I never experienced like this..
That is all I can say now....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree with you. Reset for my Router and ISP router was done. ISP Modem replaced for a borrowed one, my XR500 repleaced ny Linksys AC 1200, but everything remains the same, nothing helped... I am not using VPN, however one time was set pure VPN, but not now, and there was reset, and another Home Router as well..I think I have no any extra thing, and not set anything that could cause this problem.. as I mentioned one day I got up and met my unique .. special problem, from my side nothing has changed.
How ever , I checked my XR500 logs, and I have DOS attacks like this,
But it can not cause the problem, Can it?
[DoS Attack: TCP/UDP Chargen] from source: 14.135.120.21, port 54152, Saturday, May 11, 2019 16:55:00 [DoS Attack: TCP/UDP Chargen] from source: 205.205.150.21, port 50992, Saturday, May 11, 2019 16:55:00 [DoS Attack: TCP/UDP Echo] from source: 14.135.120.21, port 53227, Saturday, May 11, 2019 16:50:29 [DoS Attack: TCP/UDP Echo] from source: 205.205.150.21, port 49906, Saturday, May 11, 2019 16:50:29 [DoS Attack: SYN/ACK Scan] from source: 89.248.162.131, port 22, Saturday, May 11, 2019 16:34:0
- Mark as New
- Bookmark
- Subscribe
- Permalink
No those DoS entries are very normal, it won't be to do with that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have upgraded XR500, after restarted ISP kabel modem and my XR500. Still not connected to COD servers, but totally different Error CODE came up than previously..attached the picture.
By the way, Can I keep this new upgrade?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Theres quite a few potential fixes located here from what I can see: https://community.callofduty.com/t5/Infinite-Warfare-Support/How-to-fix-error-code-32770/td-p/100785...
Recommend you take a look through and fix them, some are simple such as need to verify Sony email address or play a LAN game then quit then play online.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your help @Netduma-Fraser
I will check everything, and what you wrote..
Thanks again
